[Qgis-developer] DWG/DXF Import on Linux
Andreas Neumann a.neumann at carto.net
Thu Dec 22 06:46:35 PST 2016
Hi Pedro,
What version of GDAL are you using? Geopackage support needs >= 2.0, for
some geopackage features even higher. Many Linux distros ship with older
GDAL releases.
Do you have the libdxfrw libray installed?
On Linux your best bet to test the very latest releases of the libs and
QGIS would be to self-compile all the necessary libraries
(GDAL/libdxfrw) and QGIS. I did it that way and it works fine.
Andreas
On 22.12.2016 15:41, Pedro Venâncio wrote:
> Hi Jürgen
> I'm testing DWG/DXF Import tool, and it works great on Windows!
> But it does not work here on Linux. On Linux, when I try to import the
> DWG, it says:
> "Could not open layer list" and then
> "Drawing import failed ()".
> Also, when I try to open (on Linux) a geopackagofe created with
> DWG/DXF Import on Windows, it says:
> "Invalid Data Source: /home/pedro/.../xxx.gpkg is not a valid or
> recognized data source".
> It's not ready for Linux yet?
> Another great work! Thank you very much!
> Best regards,
> Pedro Venâncio
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161222/f69cd485/attachment.html>
