[Qgis-developer] Help needed setting up Ubuntu build environment
Bas Couwenberg
sebastic at xs4all.nl
Thu Feb 11 04:20:16 PST 2016
On 2016-02-11 13:11, David Adler wrote:
> Unfortunately, section 3.3 with the build dependencies is cut off on
> the right side. Is there another link for the entire document?
You can view the raw file via the link in GitHub, or just select the
line a drag it to right to reveal the rest of the line.
https://raw.githubusercontent.com/qgis/QGIS/master/INSTALL
You can also easily install the qgis build dependencies with apt:
sudo apt-get build-dep qgis
Kind Regards,
Bas
