[Qgis-developer] A common set of functions for QGIS plugins
Nathan Woodrow
madmanwoo at gmail.com
Fri Feb 19 01:22:07 PST 2016
Given that we have 3.0 on the cards and that has a planned API break and
refactor I think this stuff is better planned for that so we can all focus
effort on making that good.
Thoughts?
On Fri, Feb 19, 2016 at 6:35 PM, Etienne Trimaille <
etienne.trimaille at gmail.com> wrote:
> I'm discovering that 'old' topic.
> Yes, I really like the idea, but I wasn't aware about that.
> I think the UI should be more uniform between plugins and QGIS, for
> instance to have :
> - the same combobox about layers (using the symbol for the geometry type
> and the EPSG if the checkbox is checked in the Processing settings)
> - the same combobox for table fields (symbol with the kind of field :
> integer, char ...)
> - the same output field with the menu (save to temp file, save to vector
> file, save to ...) like in processing.
> So I will try to use that and contribute to these wrappers if I can.
> By the way, is it possible to recommend on the pyqgis cookbook (or the
> qgis documentation) to use the processing framework more often ? A lot of
> plugins are useful but we can't use them in batch mode or in complex
> workflow. Moreover, they often produce only shapefile.
> There are some very nice settings in Processing like "use selected
> features", default output format for vector and raster ... I think plugins
> should try to more compliant with these settings.
> 2016-02-19 8:55 GMT+01:00 Paolo Cavallini <cavallini at faunalia.it>:
>> Il 19/02/2016 08:53, Victor Olaya ha scritto:
>> > I dont think it wil hurt to add it to the main repo. While we develop,
>> > and the methods are not used yet, it will be just a bunch of files
>> > with dead code, so it is not risky, and maybe it is easier to engage
>> > people that way
>> I'd vote for it.
>> Thanks, Victor.
>> Paolo Cavallini - www.faunalia.eu
>> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160219/6b1356b1/attachment.html>
