[Qgis-developer] [Qgis-user] Qgis failed to startup
Matthias Kuhn
matthias at opengis.ch
Tue Jun 14 22:19:42 PDT 2016
It could be an issue with libraries.
The application is linked against one you built yourself and runtime
picks up a system library.
LD_LIBRARY_PATH might help in this situation.
On 06/14/2016 06:38 PM, BOKU wrote:
> okay i did all again same thing in ./output/./qgis
> speichrzugriffsfehler
> ??? i've no idea what is causing that?
> On 2016-06-14 10:14, Matthias Kuhn wrote:
>> Hi Christoph
>> On 06/13/2016 10:03 PM, christoph wrote:
>>> Hi, I built Qgis from git clone source,
>>> ccmake ..
>>> make -> without any errors,
>>> make install -> without any errors
>>> Qgis/build/bin/ qgis error -> Speicherzugriffsfehler
>>> anyone a idea what is causing that?
>>> christoph at excelsior:~/myworld/QGIS/build/bin$ ./qgis
>> Either run the installation
>> make install
>> qgis
>> Or run from the build folder (isolated, I use that for development)
>> make
>> ./output/bin/qgis
>> Not sure if it's this but it could potentially lead to qgis picking
>> up wrong libraries.
>> Cheers Matthias
>>> cheers chris
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Matthias Kuhn
>> OPENGIS.ch - https://www.opengis.ch
>> Spatial • (Q)GIS • PostGIS • Open Source
Matthias Kuhn
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160615/7daa6dfc/attachment.html>
