[Qgis-developer] Report 5 - QGIS Symbology Sharing Tools
Matthias Kuhn
matthias at opengis.ch
Sun Jun 26 10:50:03 PDT 2016
Hi Akbar,
thanks a lot for the update, I especially liked the video, this makes it
a lot easier for the audience (at least me :) ) to get an impression of
the status quo. Good job so far!
Concerning dulwich, did you checkout the #dulwich IRC channel and the
mailing list which are mentioned in the project's readme [1] ?
What exactly are the efficiency problems you are referring to? Maybe
it's also worth looking into downloading individual files over http
instead of the whole .zip file (raw.githubusercontent.com), that also
allows doing partial downloads if you don't need a complete repository
and you know which files you want.
Looking forward to hearing more of this project, keep up the good work!
Matthias
[1] https://github.com/jelmer/dulwich#help
On 06/26/2016 07:10 PM, Akbar Gumbira wrote:
> Hi,
> I made a video of the progress so
> far: https://www.youtube.com/watch?v=OmJ2Vh3a63U
> *What did you get done this week?*
> * Saving the metadata of the collections to local as a cache (after
> some operations like adding/removing/deleting repository) so that
> when user doesn't have internet, (s)he will still be able to browse
> collection.
> * Filtering collections with custom QSortFilterProxyModel to allow
> filtering based on author, name, description, etc.
> * Fix unicode problem (The problem is when parsing the metadatafile.
> Using ConfigParser it was read as str. Changed it to
> SafeConfigParser with codecs module)
> * Implemented reload repositories. Also when fetching metadata, never
> use cache
> * Implemented Ale's suggestion to have a directory file in official
> repository and containing available repositories (and by default all
> those repositories will be registered in the plugin)
> * Still thinking to use git as it will be more efficient rather than
> using zip url and tried Dulwich (Python pure git implementation),
> but it's freezing the UI (see the video above)
> *What do you plan on doing next week?*
> * My code is getting harder to read. Need to refactor some and make tests
> * Tried to load a repository that contains 1000 collections. Right
> now, I just saved the metadata's cache (dict) to the qsettings. The
> QGIS config file is getting too big. WIll move this to a separate
> pickled file.
> * Explored Dulwich more
> Are you blocked on anything?
> I have problem with Dulwich. It's freezing the UI. I want to show the
> progress of cloning/pulling repository realtime but I haven't figured
> out a way yet.
> *Akbar Gumbira *
> *www.akbargumbira.com <http://www.akbargumbira.com>*
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
