[Qgis-developer] Proposed plan to fix issue with concurrent opening of OGR datasources (aka QGIS and MapInfo)
Even Rouault even.rouault at spatialys.com
Tue Mar 22 02:31:47 PDT 2016
I'm considering addressing an issue that mainly involves concurrent use of a
MapInfo TAB dataset by QGIS and MapInfo, as described in
https://hub.qgis.org/issues/14378, although the planned fix would be a bit more
general.
The problem is that when QGIS opens a OGR datasource it tries to open it with
the update mode of the OGROpen() API, which in turn opens the underlying
file(s) with a mode (dwDesiredAccess = GENERIC_READ | GENERIC_WRITE and
dwShareMode =
FILE_SHARE_READ | FILE_SHARE_WRITE with the Windows CreateFile API()) that is
incompatible with the mode with which MapInfo tries to open files in read-only
(dwDesiredAccess = GENERIC_READ and dwShareMode =
FILE_SHARE_READ). Hence MapInfo cannot open a MapInfo dataset already opened
by QGIS in update mode.
The solution I'm considering would be to modify the QGIS OGR provider to :
- try to open the dataset in update mode as currently, but if it is
successful, go back to re-opening it in read-only mode. (we need to try to
open in update mode so as to have appropriate capabilities)
- for operations like addFeatures(), addAttributes(), etc ... that need update
permissions, check the current open mode, and if not update mode already, re-
open the OGR datasource in update mode
- go back to read-only mode when the user exists the edition mode (this would
need a new method in the QgsVectorDataProvider API to warn about that, since
the provider has currently no way of knowing that)
There would be of course a cost to pay due to this open / close operations, so
I think I would limit it to shapefiles and mapinfo for now, since the opening
of such datasets doesn't involve a lot of I/O ( the most costly is for
shapefiles where the whole .shx is ingested into memory ).
Another related fix would be to implement reloadData() in the OGR provider so
that the user can resynchronize its QGIS session for a dataset modified by
another software.
Thoughts ?
Even
http://www.spatialys.com
