[Qgis-developer] Any UI/UX plans for QGIS3?
    Tim Sutton
    tim at kartoza.com
    Fri Nov 25 21:02:50 PST 2016
Hi
> Another one I forgot to add (a bit unrelated):
> - lots of the processing algorithms don't correctly handle z/m
> geometries and the changes are often trivial to allow them to. I'd
> love to see someone generate a list (based off master) of all the
> algorithms which currently don't maintain z and m values and which
> should.
And another big one would be to make QGIS expressions the standard way for entering expressions (thinking about raster calculator and layer filter expression dialog for example). Maybe the expression dialog should have a 'SQL' and "QGIS' mode so that it can use the same UI but constrain expressions to valid SQL if the recipient of the expression requires valid SQL.
Regards
Tim
> Nyall
>> These are also issues for plugins, so collating lists and opening bugs
>> against plugins would also help.
>>> Help and Documentation
>>> - Most of our help buttons lead to nowhere, we already talked about pointing
>>> them to the User's Manual online (although we would need a solution for
>>> working with it offline and in different languages)
>>> Defaults
>>> - Should default selection color not be opaque?
>>> - Showing only selected features vertexes by default?
>> +1
>>> - Map template, we could provide a very simple template as default (I think
>>> there was already some discussion about this); Most people I see gets very
>>> confused when they see a completely empty page.
>> Depends how it's done. I don't think it should always open with a
>> template, but including some nice templates with qgis would be a good
>> start.
>> Another idea I'd love to see for 3.0 is switching the main ui to using
>> monochrome "symbolic" icons. I think this could really refresh the
>> interface and avoid the ui from taking attention away for the content
>> (ie, the pretty map you're making). I tried making a script to auto
>> convert the icons as a test.... and ended up with a horrendous result
>> which had to be burned in a furnace and scattered on the four winds.
>> Nyall
>>> Alexandre Neto
>>> Alexandre Neto
>>> @AlexNetoGeo
>>> http://sigsemgrilhetas.wordpress.com
>>> http://gisunchained.wordpress.com
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
Co-founder: Kartoza
Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161126/4def51c7/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161126/4def51c7/attachment-0001.jpg>
