[Qgis-developer] Sandboxing python
geodrinx at gmail.com geodrinx at gmail.com
Mon Oct 17 03:06:46 PDT 2016
Inviato da iPhone
> Il giorno 17 ott 2016, alle ore 11:19, Nathan Woodrow <madmanwoo at gmail.com> ha scritto:
> For context from here: https://lwn.net/Articles/574215/
> "I now agree that putting a sandbox in CPython is the wrong design. There are too many ways to escape the untrusted namespace using the various introspection features of the Python language. To guarantee the [safety] of a security product, the code should be [carefully] audited and the code to review must be as small as possible. Using pysandbox, the "code" is the whole Python core which is a really huge code base. For example, the Python and Objects directories of Python 3.4 contain more than 126,000 lines of C code.
> The security of pysandbox is the security of its weakest part. A single bug is enough to escape the whole sandbox."
Correct.  In fact I am talking about this other:
pypy.org  and its sandboxing, that is:
http://doc.pypy.org/en/latest/sandbox.html?highlight=Sandboxing
that reports the interesting issues you can have with other solutions, as CPython, for example.
Do you have read it ?  If not, good reading  :)
>> On Mon, Oct 17, 2016 at 7:17 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>> Honestly, this is getting tiresome.
>> If you don't like the approval processes that we have in place currently you can create a new plugin repo, it's just an XML file exposed via webserver, there are docs around for it.
>> You can give this URL to people and they can install your plugins via that.
>> If you don't want to do that, then you will have to go through the approval process.  I'm sure there are reasons it took longer than normal, maybe review those first.
>> If you want to follow the sandboxed Python route and see how far you get fine, however again I suspect you are in for a long road given the complex nature of that and you would still have to
>> be able to support what we can in core, etc.
>> - Nathan
>>> On Mon, Oct 17, 2016 at 6:31 PM, Geo DrinX <geodrinx at gmail.com> wrote:
>>> 2016-10-17 10:19 GMT+02:00 Nathan Woodrow <madmanwoo at gmail.com>:
>>>> Qgis uses CPython. You also have to sandbox Qt, so I suspect you are running into a lot of dead ends.
>>> Thank you for the suggestion.  We will see who is moving in dead ends.   :)
>>> I am the crow's nest of the ship and I am experiencing the arrival of the iceberg.
>>> And I hear the orchestra playing :)
>>> Best regards and wishes for a safe journey.   ;)
>>> Geo
>>> PS:  and then if you want to exit from the one direction maze you are going,  here I am.
>>> PPS:  in the meantime, take a look of this competition:    https://goo.gl/WR8LVF
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161017/f8770e8d/attachment-0001.html>
