[Qgis-developer] [QGIS Server] Maintain it and create a team
David Marteau
dmarteau at 3liz.com
Mon Sep 26 08:08:20 PDT 2016
Hi
Are you telling that the server codebase could rely on these features (multiproject management and layer cache) with
the actual refactoring ? This would be really a good thing - (and also a better handling of the layer registry that introduces weird
things with the ownership of layers).
Afaik, trying to genuinely load a project in a headless qgis leads to a crash, and this why the server had to
manage things on its own.
Regards
David
> Le 26 sept. 2016 à 16:44, Jürgen E. Fischer <jef at norbit.de> a écrit :
> Hi Andreas,
> On Mon, 26. Sep 2016 at 14:37:30 +0200, Neumann, Andreas wrote:
>> I have to say it comes a bit as a surprise to me that suddenly QGIS
>> server is not regarded as a core component of QGIS anymore.
> Me too. To me it's also not so clear why it should be separated more from
> core. I guess it would be better to make core more suitable for use with the
> server. So all the special things it now does to manage multiple projects and
> caching of layers across projects should be already covered there and don't
> have to be reinvented in the server in a different way.
> I also don't clearly see how moving it to a separate repository with a separate
> release schedule will make things easier. My expectation would be that it
> then would need to support multiple versions of core. And keeping it in sync
> with the cores would need extra effort by the server team, that is now covered
> with the rest of the following changes to gui, app etc. by whoever does change
> core.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
