[Qgis-developer] [QGIS Server] Maintain it and create a team
G. Allegri
giohappy at gmail.com
Mon Sep 26 08:48:00 PDT 2016
I would prefer mantaining it in QGIS core too, but we need to find the
resources to keep it up to date with QGIS 3 refactoring. I thought this was
the problem...
giovanni
Il 26 set 2016 17:08, "David Marteau" <dmarteau at 3liz.com> ha scritto:
> Hi
> Are you telling that the server codebase could rely on these features
> (multiproject management and layer cache) with
> the actual refactoring ? This would be really a good thing - (and also a
> better handling of the layer registry that introduces weird
> things with the ownership of layers).
> Afaik, trying to genuinely load a project in a headless qgis leads to a
> crash, and this why the server had to
> manage things on its own.
> Regards
> David
> > Le 26 sept. 2016 à 16:44, Jürgen E. Fischer <jef at norbit.de> a écrit :
> > Hi Andreas,
> > On Mon, 26. Sep 2016 at 14:37:30 +0200, Neumann, Andreas wrote:
> >> I have to say it comes a bit as a surprise to me that suddenly QGIS
> >> server is not regarded as a core component of QGIS anymore.
> > Me too. To me it's also not so clear why it should be separated more
> from
> > core. I guess it would be better to make core more suitable for use
> with the
> > server. So all the special things it now does to manage multiple
> projects and
> > caching of layers across projects should be already covered there and
> don't
> > have to be reinvented in the server in a different way.
> > I also don't clearly see how moving it to a separate repository with a
> separate
> > release schedule will make things easier. My expectation would be that
> it
> > then would need to support multiple versions of core. And keeping it in
> sync
> > with the cores would need extra effort by the server team, that is now
> covered
> > with the rest of the following changes to gui, app etc. by whoever does
> change
> > core.
> > Jürgen
> > Jürgen E. Fischer norBIT GmbH Tel.
> +49-4931-918175-31
> > Dipl.-Inf. (FH) Rheinstraße 13 Fax.
> +49-4931-918175-50
> > Software Engineer D-26506 Norden
> http://www.norbit.de
> > QGIS release manager (PSC) Germany IRC: jef on
> FreeNode
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160926/53da6c81/attachment.html>
