[Qgis-developer] Raster to Vector conversion
Sai Harsh Tondomker
saiharsh.t13 at iiits.in
Thu Apr 13 02:24:26 PDT 2017
Thanks, Jorge,
For your valuable reply. Can you suggest some algorithm that I can start
implementing as I have some basic knowledge of OpenCV.
Awaiting for your positive response.
Thanks & Regards,
Harsh
<https://mailtrack.io/> Sent with Mailtrack
<https://mailtrack.io/install?source=signature&lang=en&referral=saiharsh.t13@iiits.in&idSignature=22>
On Thu, Apr 13, 2017 at 1:18 PM, Jorge Gustavo Rocha <jgr at di.uminho.pt>
wrote:
> Hi Sai Harsh,
> I would start by learning OpenCV [1]. OpenCV is a sophisticated image
> processing library with Python bindings you can use with QGIS. You can
> write your own algorithm to isolate the roads. Search the web for object
> detection and classification examples.
> Machine learning is probably the best approach. You have already images
> with roads, so you have many examples for machine learning (positive
> cases). So, after playing with OpenCV, look for machine learning (with
> OpenCV).
> Regards,
> Jorge Gustavo
> [1] http://opencv.org/
> Às 06:58 de 13-04-2017, Sai Harsh Tondomker escreveu:
> > Dear All,
> > I am Sai Harsh, an UG student in IIIT-Chittoor, India.
> > I want to convert raster image to vector shape layer. I knew that in
> > qgis this feature already exists but it's limited.
> > Let us suppose If one google roadmap image is given as an input, after
> > converting it into vector shape layer(using the existing conversion), I
> > would like to highlight one road line(manually using attribute table)
> > but it's not working. correct me if I am wrong.
> > Can anyone suggest me how I need to proceed?
> > I know there should be some image processing algorithm need to be
> > applied, then followed by converting it into vector layer format.
> > Which image processing algorithm I need to apply to get good accuracy?
> > Awaiting for a positive response.
> > Best Regards,
> > Harsh
> > IIIT-Chittoor
> referral=saiharsh.t13 at iiits.in&idSignature=22>
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Tel: +351 253604480
> Fax: +351 253604471
> Móvel: +351 910333888
> skype: nabocudnosor
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170413/faa1eca7/attachment-0001.html>
