[Qgis-developer] DWG/DXF Import -- Geopackage
Tudor Barascu
tudorbarascu at yahoo.com
Sun Apr 16 23:44:42 PDT 2017
Hi Stephane,
That button is for importing DWG/DXF. It does the import into a Geopackage.
Don't know why it's stored under "Project"
All the best,Tudor
On Monday, April 17, 2017 8:02 AM, Stéphane Henriod <stephanebek at gmail.com> wrote:
Hi all
while updating the doc to describe a future unique "Add data" button https://docs.google.com/document/d/1aMX9jOfl10q8oETRzOHSHnRpHCc7UJ1dDnCCq3VyTAY/edit?usp=sharing I stumbled upon the Project / DWG/DXF Import.
2 questions here:
- Is there a reason why this import tool is stored under "Project"? Doesn't seem consistent to me but maybe I am missing a point
- It's quite confusing that the menu is called "DWG/DXF" while it is actually here to import Geopackage layers
Also, when trying to import this sample dataset http://www.geopackage.org/data/gdal_sample_v1.2_no_extensions.gpkg I get an error "Could not open layer list", although all goes well if I drag-and-drop from the browser.
Not sure if I should open a bug report or if this is all being taken care of already?
Cheers
Stéphane
“When you travel, remember that a foreign country is not designed to make you comfortable. It is designed to make its own people comfortable." -- Clifton Fadiman
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170417/1a3da9d1/attachment-0001.html>
