[Qgis-developer] DWG/DXF Import -- Geopackage
Ramon Andinach
custard at westnet.com.au
Mon Apr 17 02:55:20 PDT 2017
I’m pretty sure it’s there because if you export to DXF you either export the view or the entire project - but either way it’s not just a single layer that’s affected.
-ramon.
> On 17 Apr 2017, at 16:37, Stéphane Henriod <stephanebek at gmail.com> wrote:
> Ok, thanks for the clarification!
> Then I guess that the window should be re-designed a bit. To me at least it was not intuitive that "Geopackage" has to do with the output of the tool.
> And yes, maybe both "DXF Export" and "DWG/DXF import" could be moved somewhere else?
> Cheers
> Stéphane
> Le lundi 17 avril 2017, Tudor Barascu <tudorbarascu at yahoo.com <mailto:tudorbarascu at yahoo.com>> a écrit :
> Hi Stephane,
> That button is for importing DWG/DXF. It does the import into a Geopackage.
> Don't know why it's stored under "Project"
> All the best,
> Tudor
> On Monday, April 17, 2017 8:02 AM, Stéphane Henriod <stephanebek at gmail.com <>> wrote:
> Hi all
> while updating the doc to describe a future unique "Add data" button https://docs.google.com/document/d/1aMX9jOfl10q8oETRzOHSHnRpHCc7UJ1dDnCCq3VyTAY/edit?usp=sharing <https://docs.google.com/document/d/1aMX9jOfl10q8oETRzOHSHnRpHCc7UJ1dDnCCq3VyTAY/edit?usp=sharing> I stumbled upon the Project / DWG/DXF Import.
> 2 questions here:
> Is there a reason why this import tool is stored under "Project"? Doesn't seem consistent to me but maybe I am missing a point
> It's quite confusing that the menu is called "DWG/DXF" while it is actually here to import Geopackage layers
> Also, when trying to import this sample dataset http://www.geopackage.org/data/gdal_sample_v1.2_no_extensions.gpkg <http://www.geopackage.org/data/gdal_sample_v1.2_no_extensions.gpkg> I get an error "Could not open layer list", although all goes well if I drag-and-drop from the browser.
> Not sure if I should open a bug report or if this is all being taken care of already?
> Cheers
> Stéphane
> “When you travel, remember that a foreign country is not designed to make you comfortable. It is designed to make its own people comfortable." -- Clifton Fadiman
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170417/b3aa6b74/attachment-0001.html>
