[Qgis-developer] DWG/DXF Import -- Geopackage
Stéphane Henriod stephanebek at gmail.com
Mon Apr 17 03:14:15 PDT 2017
That would indeed make sense for the "DXF export"
But maybe less for the "DWF/DXF import", which is, basically, a format
transformation (so, for the "Vector" menu) and / or a way to add data to
the canvas.
Or, again, maybe I am missing a point :-)
Stéphane
Le lundi 17 avril 2017, Ramon Andinach <custard at westnet.com.au> a écrit :
> I’m pretty sure it’s there because if you export to DXF you either export
> the view or the entire project - but either way it’s not just a single
> layer that’s affected.
> -ramon.
> On 17 Apr 2017, at 16:37, Stéphane Henriod <stephanebek at gmail.com
> <javascript:_e(%7B%7D,'cvml','stephanebek at gmail.com');>> wrote:
> Ok, thanks for the clarification!
> Then I guess that the window should be re-designed a bit. To me at least
> it was not intuitive that "Geopackage" has to do with the output of the
> tool.
> And yes, maybe both "DXF Export" and "DWG/DXF import" could be moved
> somewhere else?
> Cheers
> Stéphane
> Le lundi 17 avril 2017, Tudor Barascu <tudorbarascu at yahoo.com
> <javascript:_e(%7B%7D,'cvml','tudorbarascu at yahoo.com');>> a écrit :
>> Hi Stephane,
>> That button is for importing DWG/DXF. It does the import into a
>> Geopackage.
>> Don't know why it's stored under "Project"
>> All the best,
>> Tudor
>> On Monday, April 17, 2017 8:02 AM, Stéphane Henriod <
>> stephanebek at gmail.com> wrote:
>> Hi all
>> while updating the doc to describe a future unique "Add data" button
>> https://docs.google.com/document/d/1aMX9jOfl10q8oE
>> TRzOHSHnRpHCc7UJ1dDnCCq3VyTAY/edit?usp=sharing I stumbled upon the *Project
>> / DWG/DXF Import*.
>> 2 questions here:
>>    - Is there a reason why this import tool is stored under "Project"?
>>    Doesn't seem consistent to me but maybe I am missing a point
>>    - It's quite confusing that the menu is called "DWG/DXF" while it is
>>    actually here to import Geopackage layers
>> Also, when trying to import this sample dataset http://www.geopackage.
>> org/data/gdal_sample_v1.2_no_extensions.gpkg I get an error "Could not
>> open layer list", although all goes well if I drag-and-drop from the
>> browser.
>> Not sure if I should open a bug report or if this is all being taken care
>> of already?
>> Cheers
>> Stéphane
>> “When you travel, remember that a foreign country is not designed to make
>> you comfortable. It is designed to make its own people comfortable." --
>> Clifton Fadiman
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Clifton Fadiman
> <javascript:_e(%7B%7D,'cvml','Qgis-developer at lists.osgeo.org');>
Clifton Fadiman
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170417/6e48bb68/attachment.html>
