[Qgis-developer] [gdal-dev] GDAL 2.2.0 beta 2 available
Matthias Kuhn
matthias at opengis.ch
Mon Apr 24 13:21:28 PDT 2017
Hi Even,
In the end, isn't solution 2) the same as solution 1) for the user? In
which case it sounds like it mainly puts additional load on
distributions for no added value. Am I missing something?
Especially because "some other workflows" is a quite loose definition.
In the end it sounds like the proper solutions would be to fix dxf2shp -
but since that has already been sent to the graveyard it's questionable
if someone wants to do the effort.
More options
4) ship shapelib with qgis itself (as part of the dxf2shp plugin)
5) require GDAL < 2.2 for building QGIS 2.18
Matthias
On 4/24/17 7:20 PM, Even Rouault wrote:
> Hi,
> > - Shape: do not export Shapelib symbols for builds
> > --with-hide-internal-symbols (#6860)
> It turns out that the above change breaks QGIS 2.18 build, in
> particular the DXF2SHP converter native plugin, since it does a nasty
> trick: the QGIS build tree has the shapelib 2.10 includes files, but
> relies on linking against shapelib symbols exported by libgdal. The
> plugin apparently no longer exists in QGIS master, which builds fine
> against GDAL 2.2beta2.
> So I'm not sure what to do:
> 1) revert #6860 and export again shapelib symbols from GDAL. But this
> apparently breaks some other workflows
> 2) let distributions apply a patch to do this revert, while they use
> QGIS 2.18 or other code that depend on GDAL exporting shapelib symbols
> 3) Change DXF2SHP plugin to use OGR API instead of shapelib, but I'm
> not feeling like I would do that myself.
> My opinion would be to favor 2)
> Opinions ?
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170424/9d7f8861/attachment.html>
