[Qgis-developer] Processing: gdal_calc generates Python.exe has stopped working on Windows
Alexander Bruy
alexander.bruy at gmail.com
Tue Apr 25 05:23:08 PDT 2017
Hi René-Luc,
I have also seen this issue several times, and for me it also happen
not only wth gdal_calc but also with other Python-based GDAL tools.
I did not reported it because I was unable to produce stable test case.
2017-04-25 11:05 GMT+03:00 René-Luc Dhont <rldhont at gmail.com>:
> Hi Jürgen,
> Thanks for your answer.
> I wonder if other QGIS user on Windows has already tested the GDAL
> calculator and have the same issue as the reporter and my customer.
> About Osgeo4W, we have opened a tickets 4 years ago about PHP to help users
> tested Lizmap and QGIS Server on windows, but we nerver have any reaction
> https://trac.osgeo.org/osgeo4w/ticket/343
> I know that QGIS is build with some packages coming from OSgeo4W, I suppose
> that some part of the project are maintained and I thank you those who do
> it.
> Regards,
> René-Luc
> Le 24/04/2017 à 11:46, Jürgen E. Fischer a écrit :
> Hi René-Luc,
> On Mon, 24. Apr 2017 at 11:21:50 +0200, René-Luc Dhont wrote:
> Does someone else has encountered this issue ?
> The reporter.
> Do you know if Osgeo4W is maintained ?
> Depends how you define it.
> Jürgen
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
