[Qgis-developer] processing modeler: join attributes table
Martin Landa
landa.martin at gmail.com
Thu Apr 27 06:27:04 PDT 2017
we are trying to join attribute table with another table in processing
modeler (using "Join attributes table" algorithm), but it fails:
Running Join attributes table [2/2]
Parameters: INPUT_LAYER
=/tmp/processingb49e46d91a8d4997a4d2c2b0a2e31e7c/94a754a43e4a4074bcbd79714a0eebcf/OUTPUTALGQGISUNION1.shp,
INPUT_LAYER_2 =/home/landa/Documents/YFSG/hydrologie/hydrologie/vzorek1/hpj.shp,
TABLE_FIELD =HPJ, TABLE_FIELD_2 =HPJ
Failed
Error executing algorithm Join attributes table
QgsFeature.setGeometry(QgsGeometry): argument 1 has unexpected type
'NoneType' See log for more details
The parameters should be fine - the both tables (attribute table and
CSV table contain column 'HPJ'). It's possible to join CSV table file
with attribute table manually in QGIS without any problems. It seems
to be a bug in processing modeler, can you confirm it?
Thanks, Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
