[Qgis-developer] option to set a global padding for layer labeling
G. Allegri
giohappy at gmail.com
Thu Apr 27 14:56:06 PDT 2017
This requirement stems from the concept of "metabuffer" in tile caching, a
mechanism commonly user to mitigate label artifacts around tiles' margins.
I suppose that adding such opton would be as simple as reducing the bbox
set inside QgsLabelingEngine::run by the required amount, and obviously
adding the setting to the layers' labeling settings UI.
What's your opinion?
giovanni
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170427/964dee19/attachment.html>
