[QGIS-Developer] Load vector layer in Processing
Giovanni Manghi giovanni.manghi at gmail.com
Sun Aug 6 10:19:34 PDT 2017
> Hi all,
> loading a layer from the filesystem in a Processing module (I tried
> several, e.g. remove holes) does not filter layer types; this is
> confusing, only vector extensions should be shown.
on master? 2.18?
On 2.18 it shows all the files by default, as the normal "add vector
layer" dialog, then you have the "files of type" dropdown to select a
specific type of vector data source, as the normal "add vector layer"
dialog.
-- G --
More information about the QGIS-Developer mailing list
