[QGIS-Developer] Load vector layer in Processing
Paolo Cavallini
cavallini at faunalia.it
Sun Aug 6 10:25:13 PDT 2017
Il 06/08/2017 19:19, Giovanni Manghi ha scritto:
>> Hi all,
>> loading a layer from the filesystem in a Processing module (I tried
>> several, e.g. remove holes) does not filter layer types; this is
>> confusing, only vector extensions should be shown.
> on master? 2.18?
I noticed it on master
> On 2.18 it shows all the files by default, as the normal "add vector
> layer" dialog, then you have the "files of type" dropdown to select a
> specific type of vector data source, as the normal "add vector layer"
> dialog.
there is only all files and an empty entry
all the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
