[QGIS-Developer] zzz-db_manager-5-depend : qgis build failed
nihcas nihcas.c76 at gmail.com
Tue Aug 29 01:06:45 PDT 2017
I am trying to compile QGIS master over Windows 10 and VS 2015 x64 and
getting the error:
1>------ Build started: Project: version, Configuration: RelWithDebInfo x64
2>------ Build started: Project: ui, Configuration: RelWithDebInfo x64
3>------ Build started: Project: zzz-db_manager-5-depend, Configuration:
RelWithDebInfo x64 ------
3>  Building Custom Rule
C:/QGIS/python/plugins/db_manager/db_plugins/postgis/plugins/versioning/CMakeLists.txt
3>  CMake does not need to re-run because
C:\BUILD5\python\plugins\db_manager\db_plugins\postgis\plugins\versioning\CMakeFiles\generate.stamp
is up-to-date.
3>  Generating ui_DlgVersioning.py
3>C:\Program Files
(x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppCommon.targets(171,5):
error MSB6006: "cmd.exe" exited with code -1073741819.
========== Build: 2 succeeded, 1 failed, 10 up-to-date, 0 skipped ==========
Any solution to this?
View this message in context: http://osgeo-org.1560.x6.nabble.com/zzz-db-manager-5-depend-qgis-build-failed-tp5332868.html
Sent from the QGIS - Developer mailing list archive at Nabble.com.
More information about the QGIS-Developer mailing list
