[QGIS-Developer] zzz-db_manager-5-depend : qgis build failed
Jorge Gustavo Rocha
jgr at di.uminho.pt
Tue Aug 29 04:50:57 PDT 2017
Hi nihcas,
There are updated instructions to build QGIS on Windows (submitted as PR
#4990 during the hackfest in Nødebo).
Take a look at the instructions:
https://github.com/imiara/QGIS/blob/8726146feda8932e4d47e148c8dbba163f179421/doc/msvc.t2t
If you find something missing on these instructions, please let us know.
Regards,
Jorge
On 29-08-2017 09:06, nihcas wrote:
> I am trying to compile QGIS master over Windows 10 and VS 2015 x64 and
> getting the error:
> 1>------ Build started: Project: version, Configuration: RelWithDebInfo x64
> 2>------ Build started: Project: ui, Configuration: RelWithDebInfo x64
> 3>------ Build started: Project: zzz-db_manager-5-depend, Configuration:
> RelWithDebInfo x64 ------
> 3> Building Custom Rule
> C:/QGIS/python/plugins/db_manager/db_plugins/postgis/plugins/versioning/CMakeLists.txt
> 3> CMake does not need to re-run because
> C:\BUILD5\python\plugins\db_manager\db_plugins\postgis\plugins\versioning\CMakeFiles\generate.stamp
> is up-to-date.
> 3> Generating ui_DlgVersioning.py
> 3>C:\Program Files
> (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppCommon.targets(171,5):
> error MSB6006: "cmd.exe" exited with code -1073741819.
> ========== Build: 2 succeeded, 1 failed, 10 up-to-date, 0 skipped ==========
> Any solution to this?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/zzz-db-manager-5-depend-qgis-build-failed-tp5332868.html
> Sent from the QGIS - Developer mailing list archive at Nabble.com.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
