[QGIS-Developer] How to build QGIS 2.99 with 3D?
DelazJ
delazj at gmail.com
Tue Dec 5 09:35:01 PST 2017
Maybe I miss something but I fail to fully understand the link between
Matteo needs and your explanation, Patrick. it doesn't look like Matteo has
issues to build QGIS. He already does it, he compiles from source himself (
master or any other branch).
What he wants is simply a way to build QGIS with 3D enabled, thing that by
default requires an upgraded version of QT (and not available in even known
and supported distro like Ubuntu 16.04). Unless I misunderstood...
Btw, which key package is missing in Xenial since january? I also do build
with Xenial and never felt that i'm missing some key features (except 3D
but i chose to not upgrade for that - worried to break a working
environment)
Matteo, have you seen the link I sent earlier (https://www.lutraconsulting.
co.uk/blog/2017/08/06/qgis3d-build/)? Looks like there's a way to have two
versions of qt and build different QGIS depending on what's enabled....
Harrissou
2017-12-05 17:55 GMT+01:00 Patrick Dunford <enzedrailmaps at gmail.com>:
> It's a known issue that Ubuntu Xenial by itself does not include a
> required version of a key package that is needed by masters later than
> about January 2017. Attempting to build without this package will
> presumably fail. This is why Ubuntugis based versions of Qgis are needed to
> install on Xenial or supported earlier editions of Ubuntu.
> However as per my other comment it is possible the Mint developers have
> updated this package in Mint. We have no way of predicting this without in
> depth knowledge of the distro.
> On 06/12/17 02:38, matteo wrote:
>> Hi Patrick,
>> thanks for the clarification. Actually I don't have any external
>> repository activated because I'm building QGIS from scratch and I never
>> had to add external sources.
>> Eventually, by activating the nightly repository Qt should be upgradable
>> to the last version required for 3D?
>> Thanks a lot
>> Matteo
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171205/f860082c/attachment.html>
