[QGIS-Developer] How to build QGIS 2.99 with 3D?
matteo matteo.ghetta at gmail.com
Tue Dec 5 11:40:25 PST 2017
Hi Harrissou,
> Hi,
> Maybe I miss something but I fail to fully understand the link between
> Matteo needs and your explanation, Patrick. it doesn't look like Matteo has
> issues to build QGIS. He already does it, he compiles from source himself (
> master or any other branch).
> What he wants is simply a way to build QGIS with 3D enabled, thing that by
> default requires an upgraded version of QT (and not available in even known
> and supported distro like Ubuntu 16.04). Unless I misunderstood...
that's exactly the point. I don't have any problem to build QGIS master
(and other versions).
> Btw, which key package is missing in Xenial since january? I also do build
> with Xenial and never felt that i'm missing some key features (except 3D
> but i chose to not upgrade for that - worried to break a working
> environment)
> Matteo, have you seen the link I sent earlier (https://www.lutraconsulting.
> co.uk/blog/2017/08/06/qgis3d-build/)? Looks like there's a way to have two
> versions of qt and build different QGIS depending on what's enabled....
yep I saw the link (actually also when Martin posted it a few months ago
;) ). Ok, then if this is currently the only way to have 3D enabled I'll
try to do that, hoping to not breaking some Qt or other stuff..
Thanks!
Matteo
More information about the QGIS-Developer mailing list
