[QGIS-Developer] WMS GetFeatureInfo: Test Server with JSON support?
Alessandro Pasotti
apasotti at gmail.com
Fri Dec 8 01:09:37 PST 2017
almost any GeoServer does:
http://demo.geo-solutions.it/geoserver/sf/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&FORMAT=image%2Fpng&TRANSPARENT=true&QUERY_LAYERS=sf%3Arestricted&STYLES&LAYERS=sf%3Arestricted&INFO_FORMAT=application/json&FEATURE_COUNT=50&X=50&Y=50&SRS=EPSG%3A26713&WIDTH=101&HEIGHT=101&BBOX=593689.8722436512%2C4919792.27973198%2C595617.7466318649%2C4921720.154120194
On Fri, Dec 8, 2017 at 9:38 AM, Michel Stuyts <michel.stuyts at edegem.be>
wrote:
> This server supports JSON
> https://ro.ruimtevlaanderen.be/drodsi-geoserver/wms
> Michel
> -----Oorspronkelijk bericht-----
> Van: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org]
> Namens Matthias Kuhn
> Verzonden: donderdag 7 december 2017 9:30
> Aan: qgis-developer at lists.osgeo.org
> Onderwerp: [QGIS-Developer] WMS GetFeatureInfo: Test Server with JSON
> support?
> Hi all,
> QGIS suppors querying features from a WMS. Among the supported response
> formats is JSON.
> The current code is based on QScript, which is deprecated.
> I've written some code that removes this dependency, so we can stick to
> maintained Qt code and can remove a dependency from QGIS.
> Now the state is as follows, the code is written, but I couldn't test it
> because I don't know a WMS server with this behavior.
> If someone could point me towards a server that responds with JSON
> formatted feature information, I can make sure, the new code behaves the
> way it should.
> If not, I'll just keep the old code around on any system that has QScript
> available (which should be almost any system out there) and only resort to
> the untested code when QScript is not available in the build environment.
> Thanks a lot in advance
> Matthias
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171208/d1ff65ab/attachment.html>
