[QGIS-Developer] WMS GetFeatureInfo: Test Server with JSON support?
Matthias Kuhn matthias at opengis.ch
Sun Dec 10 04:03:23 PST 2017
Thanks a lot,
looks like this works perfectly fine with this server.
Matthias
On 12/08/2017 09:38 AM, Michel Stuyts wrote:
> This server supports JSON
> https://ro.ruimtevlaanderen.be/drodsi-geoserver/wms
> Michel
> -----Oorspronkelijk bericht-----
> Van: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] Namens Matthias Kuhn
> Verzonden: donderdag 7 december 2017 9:30
> Aan: qgis-developer at lists.osgeo.org
> Onderwerp: [QGIS-Developer] WMS GetFeatureInfo: Test Server with JSON support?
> Hi all,
> QGIS suppors querying features from a WMS. Among the supported response formats is JSON.
> The current code is based on QScript, which is deprecated.
> I've written some code that removes this dependency, so we can stick to maintained Qt code and can remove a dependency from QGIS.
> Now the state is as follows, the code is written, but I couldn't test it because I don't know a WMS server with this behavior.
> If someone could point me towards a server that responds with JSON formatted feature information, I can make sure, the new code behaves the way it should.
> If not, I'll just keep the old code around on any system that has QScript available (which should be almost any system out there) and only resort to the untested code when QScript is not available in the build environment.
> Thanks a lot in advance
> Matthias
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
