[QGIS-Developer] Run processing model on selected features only
    Andreas Neumann
    a.neumann at carto.net
    Mon Dec 11 06:10:49 PST 2017
Hi Mathieu,
Thanks for the information. Unfortunately I cannot use "Feature Source"
as an input in my model.
Matthias told me that I have to use "Vector layer" as an input, because
my model relies on certain features that aren't available on "feature
source" inputs. I need to use refactor fields in a model with
expressions support for relation_aggregates and represent_value (which
requires information on widget configuration).
Is there any chance this checkbox could also be introduced for "Vector
layer" inputs? Should I open an issue?
I also find it quite confusing that the inputs come with zero
documentation. I think for probably 99% of the users who are not devs it
isn't obvious when to use which input. Could we introduce a very simple
tooltip that explains with 1 or 2 sentences what the input implies -
esp. for the "Vector layer" vs. "Feature Source" vs. "Layer field" ?
Thanks,
Andreas
On 2017-12-11 15:01, Mathieu Pellerin wrote:
> The global use only selected features option is gone (yay) in favor of a checkbox which can be activated on a per-use basis. I believe iterating through selected features only requires a vector source input.
> On Dec 11, 2017 20:57, "Andreas Neumann" <a.neumann at carto.net> wrote:
>> Hi,
>> In QGIS master (version 3), with a Vector Layer input, I am failing to find the option to run a processing model only on the selected features.
>> Can you please help me find the setting? I looked in the "Options" --> "Settings" --> "Processing" or watched out for a checkbox in the "Run model dialog" - but both did not show an option to restrict on selected features only.
>> Thanks for a hint,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer [1]
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer [1]
Links:
[1] https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171211/e9123c36/attachment.html>
