[QGIS-Developer] Run processing model on selected features only
    Andreas Neumann
    a.neumann at carto.net
    Mon Dec 11 06:37:11 PST 2017
Hi Mathieu,
If I run "Save selected features" before the rest of my model I also
loose the whole context of widgets and relations, because it is a new
virgin layer then with no link to the original layer configuration
(widgets, relations) - right?
Thanks for your reply,
Andreas
 On 2017-12-11 15:15, Mathieu Pellerin wrote:
> You could use the "save selected features" algorithm in your model against the vector layer input.
> On Dec 11, 2017 21:10, "Andreas Neumann" <a.neumann at carto.net> wrote:
> Hi Mathieu,
> Thanks for the information. Unfortunately I cannot use "Feature Source" as an input in my model.
> Matthias told me that I have to use "Vector layer" as an input, because my model relies on certain features that aren't available on "feature source" inputs. I need to use refactor fields in a model with expressions support for relation_aggregates and represent_value (which requires information on widget configuration).
> Is there any chance this checkbox could also be introduced for "Vector layer" inputs? Should I open an issue?
> I also find it quite confusing that the inputs come with zero documentation. I think for probably 99% of the users who are not devs it isn't obvious when to use which input. Could we introduce a very simple tooltip that explains with 1 or 2 sentences what the input implies - esp. for the "Vector layer" vs. "Feature Source" vs. "Layer field" ?
> Thanks,
> Andreas
> On 2017-12-11 15:01, Mathieu Pellerin wrote:
> The global use only selected features option is gone (yay) in favor of a checkbox which can be activated on a per-use basis. I believe iterating through selected features only requires a vector source input.
> On Dec 11, 2017 20:57, "Andreas Neumann" <a.neumann at carto.net> wrote:
> Hi,
> In QGIS master (version 3), with a Vector Layer input, I am failing to find the option to run a processing model only on the selected features.
> Can you please help me find the setting? I looked in the "Options" --> "Settings" --> "Processing" or watched out for a checkbox in the "Run model dialog" - but both did not show an option to restrict on selected features only.
> Thanks for a hint,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer [1]
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer [1]
Links:
[1] https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171211/55bfc12f/attachment-0001.html>
