[QGIS-Developer] Qgis r.stream.distance
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Fri Dec 15 07:09:25 PST 2017
Dear Eva,
Since r.stream.distance is a C addon, the process of getting it to work in qgis is a bit involved.
If the GRASS command line is available in qgis you could run it from there...
Cheers
Stefan
________________________________________
Von: QGIS-Developer [qgis-developer-bounces at lists.osgeo.org] im Auftrag von Eva Schindele [eva.schindele at ufz.de]
Gesendet: Freitag, 15. Dezember 2017 13:35
An: qgis-developer at lists.osgeo.org
Betreff: [QGIS-Developer] Qgis r.stream.distance
Dear All,
I use Qgis with Grass plugin, but the r.stream.distance function isn“t shown in my toolbox. Is it anyway possible to add it there?
In the modulelist, which is shown in the following link, it is even not mentioned. (https://grasswiki.osgeo.org/wiki/GRASS-QGIS_relevant_module_list)
The attempt to get it in through adding the r.strem.distance.exe- file in the folder where all modules are, failed.
What have I done wrong or what is moreover necessary to do?
I tried to figure it out a long time without any solution.
Hope to hear from you soon and thanks in advance.
Eva Schindele
