[QGIS-Developer] Support to loading GIS projects from an extended OWC geopackage in the QGIS core
Tim Sutton
tim at kartoza.com
Sat Dec 16 14:11:44 PST 2017
Hi
> On 15 Dec 2017, at 15:26, Régis Haubourg <regis.haubourg at gmail.com> wrote:
> Hi all,
> some years ago, we discussed of a new project file format able to store data and other ressources has been discussed.
> We finally had the opportunity to make one step forward when working on the auxiliary data storage stuff.
> What's the current status in QGIS 3:
> - we now have an optional format ".qgz" that is a zipped file
> - the auxiliary data storage is a sqlite database ".qgd" storing additional informations joined to classical layers (for manual labeling purposes for instance). It is NOT a spatialite database that could be the container for spatial data
> - when zip fil format is chosen, the qgd file is stored inside the qgz.
> So, the path is opened to modify the offline editing tools or other equivalent features to store their local datasource (either gpkg or sqlite) inside the qgz too.
> We also now have a container for storing SVG, color ramps, pictures or any additionnal ressource that should be shipped within the project.
> Now my opinion on the proposal about storing all inside a GPKG:
> - I think we should first have a native "packaging" format using native qgs file, to adress what offline editing, Qconsolidate, or QFieldSync use cases requires.
> - The "interoperability" use case should be adressed only as an option, not a default solution, since SLD conversion (and things that don't stick to standards) will alter the project.
> I am in favor of discussing all that after QGIS3 is out so that we keep focused on that, and then discuss that at the Madeyra hackfest. I'd be pleased to animate a workgroup to reach common agreement, guidelines, and find a plan for that.
Thanks for laying everything out so clearly Régis! One other thing I wondered about ancillary data is the ability to store images or other external resources linked to a layer - there was some discussion about how to manage this in Nødebo too….
Regards
Tim
> Best regards !
> Régis
> Le 15 déc. 2017 10:16, "Richard Duivenvoorde" <rdmailings at duif.net <mailto:rdmailings at duif.net>> a écrit :
> On 14-12-17 13:59, Alessandro Pasotti wrote:
> > Hi Joana,
> > I think this would be a great addition to QGIS.
> > Big +1 from me, and thanks for the proposal.
> > On Thu, Dec 14, 2017 at 1:49 PM, doublebyte <joana at doublebyte.net <mailto:joana at doublebyte.net>
> > <mailto:joana at doublebyte.net <mailto:joana at doublebyte.net>>> wrote:
> > Hello,
> > Maybe some of you are aware of the "geopackage" plugin
> > <https://eos.geocat.net/gitlab/joana.simoes/foss4g_gpkg/blob/master/foss4g_gpkg.pdf <https://eos.geocat.net/gitlab/joana.simoes/foss4g_gpkg/blob/master/foss4g_gpkg.pdf>
> > <https://eos.geocat.net/gitlab/joana.simoes/foss4g_gpkg/blob/master/foss4g_gpkg.pdf <https://eos.geocat.net/gitlab/joana.simoes/foss4g_gpkg/blob/master/foss4g_gpkg.pdf>>>
> > .The initial goal of this plugin was to enable users to save their QGIS
> > projects, including style and associated resources
> > in a extended geopackage - the qgis geopackage extension
> > <https://github.com/pka/qgpkg/blob/master/qgis_geopackage_extension.md <https://github.com/pka/qgpkg/blob/master/qgis_geopackage_extension.md>
> > <https://github.com/pka/qgpkg/blob/master/qgis_geopackage_extension.md <https://github.com/pka/qgpkg/blob/master/qgis_geopackage_extension.md>>>
> > and load it onto another QGIS installation; on this approach, the
> > project is
> > encoded as qgs, in a database table. Later the plugin was forked to
> > support
> > a different geopackage exension - the owc geopackage extension
> > <https://github.com/pka/qgpkg/blob/master/owc_geopackage_extension.md <https://github.com/pka/qgpkg/blob/master/owc_geopackage_extension.md> <https://github.com/pka/qgpkg/blob/master/owc_geopackage_extension.md <https://github.com/pka/qgpkg/blob/master/owc_geopackage_extension.md>>>
> > which is standards-based; in this approach
> > <https://www.geocat.net/announcing-the-extended-geopackage-qgis-plugin/ <https://www.geocat.net/announcing-the-extended-geopackage-qgis-plugin/>
> > <https://www.geocat.net/announcing-the-extended-geopackage-qgis-plugin/ <https://www.geocat.net/announcing-the-extended-geopackage-qgis-plugin/>>>
> > the style is encoded as OGC:SLD and the project as OGC:OWS context.
> > The goal
> > of this approach is to support the migration of GIS projects, as we can
> > implement this extension in any desktop or server side GIS (e.g.: ArcGIS
> > Desktop).
> > The fork was merged in August this year, and the latest release of the
> > plugin <https://plugins.qgis.org/plugins/QgisGeopackage/ <https://plugins.qgis.org/plugins/QgisGeopackage/>
> > <https://plugins.qgis.org/plugins/QgisGeopackage/ <https://plugins.qgis.org/plugins/QgisGeopackage/>>> already contains
> > both extensions, covering both use cases of porting QGIS projects and
> > migrating GIS projects. Recently, it was added support in the core
> > to the
> > "qgis geopackage extension"
> > <https://github.com/qgis/QGIS/blob/master/src/providers/ogr/qgsogrprovider.cpp#L762 <https://github.com/qgis/QGIS/blob/master/src/providers/ogr/qgsogrprovider.cpp#L762>
> > <https://github.com/qgis/QGIS/blob/master/src/providers/ogr/qgsogrprovider.cpp#L762 <https://github.com/qgis/QGIS/blob/master/src/providers/ogr/qgsogrprovider.cpp#L762>>>
> > , in the qgsogrprovider class. This means that if a user loads a
> > geopackage
> > which was encoded using the "qgis geopackage extension", it will
> > automatically load the QGIS project from it. We think that it makes
> > sense to
> > also add the "ows geopackage extension" to the core; in that case,
> > users
> > could load projects exported from other GIS software seamlessly, without
> > having to load the plugin. The mechanism would be very similar to
> > what was
> > already implemented for the "qgis geopackage extension".
> > Before preparing any Pull Request, we would like to understand first
> > what is
> > the general feeling of the community about this feature; is this
> > something
> > which seems useful and interesting to add to the QGIS core? If yes,
> > we would
> > also appreciate any comments regarding any details the implementation.
> > Looking forward to hearing your feedback :-)
> Yes, please! I think there was an issue about not being able to load an
> extended gpkg:
> https://issues.qgis.org/issues/17698 <https://issues.qgis.org/issues/17698>
> so it looks like fixing a bug
> R
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>_______________________________________________
Tim Sutton
Co-founder: Kartoza
Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171217/733e9532/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171217/733e9532/attachment-0001.jpg>
