[QGIS-Developer] Submit plugin to QGIS 3 repo
Borys Jurgiel
lists at borysjurgiel.pl
Mon Dec 18 05:32:31 PST 2017
Hi Tom,
Do you mean this version?
https://plugins.qgis.org/plugins/qgis2web/version/2.99.0/
It's set to min=2.99 and max=2.99! Not 3.99. In the metadata.txt, there is
only the min tag, not the max one.
Master seems to be a bit broken at the moment: it requests plugins for 3.0
(see the link in the Plugin Manager -> Settings: [1]), but when filtering the
received document, it finds itself 2.99.
So, for now the only solution is to add the missing max tag, and I'll try to
fix the installer to accept plugins for min=3.0 as well.
[1] https://plugins.qgis.org/plugins/plugins.xml?qgis=3.0
