[QGIS-Developer] Calling Processing Algorithm GUI From Menu
C Hamilton adenaculture at gmail.com
Tue Dec 19 06:08:49 PST 2017
What I am asking is for the API call to display a particular Processing
algorithm dialog box. For example in the processing documentation at:
https://docs.qgis.org/2.18/en/docs/user_manual/processing/console.html
there are the following calls:
processing.alglist()
processing.runalg(name_of_the_algorithm, param1, param2, ..., paramN,
       Output1, Output2, ..., OutputN)
processing.algoptions("saga:slopeaspectcurvature")
The documentation does not mention any call to display the associated
dialog box and that is what I am looking for.
Incidentally, is there processing API documentation? It doesn't appear to
be a part of the QGIS python API.
Thanks!!!
On Mon, Dec 18, 2017 at 5:39 PM, Alexandre Neto <senhor.neto at gmail.com>
wrote:
> Hi Calvin,
> In the processing options, there is a Menus (requires restart) section. In
> there, all processing algorithms should be listed, including yours. For
> each tool, you can set a menu path (separated by slashes If I recall), and
> if you what a button to show in the toolbars.
> Alexandre Neto
> C Hamilton <adenaculture at gmail.com> escreveu no dia segunda, 18/12/2017
> às 21:03:
>> I am in the process of making some of my plugins accessible to the
>> Processing Toolbox. I have it working from the processing toolbox, but how
>> do I launch the processing algorithm GUI from my plugin menu as if I were
>> double clicking on it in the toolbox?
>> Thanks,
>> Calvin
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171219/c65b65de/attachment.html>
More information about the QGIS-Developer mailing list
