[QGIS-Developer] PostGIS 3D cube lacks vertical faces
Anita Graser
anitagraser at gmx.at
Wed Dec 20 01:19:13 PST 2017
Hi Jakob,
On Wed, Dec 20, 2017 at 9:26 AM, Jakob Lanstorp <jlanstorp at gmail.com> wrote:
> Hi Anita et al,
> How did you get the geometry into QGIS. I have tried running a sql from
> within the db manager plugin on a postgis datebase like:
> SELECT
> 'POLYHEDRALSURFACE Z (
> ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)),
> ((0 0 0, 0 1 0, 0 1 1, 0 0 1, 0 0 0)),
> ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)),
> ((1 1 1, 1 0 1, 0 0 1, 0 1 1, 1 1 1)),
> ((1 1 1, 1 0 1, 1 0 0, 1 1 0, 1 1 1)),
> ((1 1 1, 1 1 0, 0 1 0, 0 1 1, 1 1 1))
> )'::geometry
> It show the polyhedral in 2D in both QGIS 2D and 3D window, but crashes
> QGIS
> when changing properties.
The crashes are a general issue reported here:
https://issues.qgis.org/issues/17416
On some machines it crashes, on others it doesn't. If you find a
non-crashing machine, you'll see the cube.
Regards,
Anita
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171220/8c6661ae/attachment.html>
