[QGIS-Developer] PostGIS 3D cube lacks vertical faces
G. Allegri
giohappy at gmail.com
Wed Dec 20 03:11:40 PST 2017
My bad Martin, I thought 3d renderer was on. Now I can see the cube
correctly.
For the zoom limit, I can understand the rationale, but it should be at
least configurable.
In this case we have a cube with a unit face and this will probably hit the
current limit, but in case of man made artifacts (buildings, etc.) these
tiny dimensions will happen frequently....
giovanni
2017-12-20 11:38 GMT+01:00 Martin Dobias <wonder.sk at gmail.com>:
> Hi Giovanni!
> On Wed, Dec 20, 2017 at 11:06 AM, G. Allegri <giohappy at gmail.com> wrote:
> > I've just updated to the latest nightly build from osgeo4w on my Dell
> XPS13
> > with Windows 10 Home Edition.
> > The result is:
> > - flat geometry inside 3d view
> > - cannot zoom more then what can be seen in the following image
> > https://photos.app.goo.gl/NjiE12dN7ajY4ASr1
> There is an intentional zoom limit to protect users from zooming in
> too much and getting strange rendering results. We could probably
> extend it a bit more if needed.
> For the flat geometry, have you enabled 3D renderer for the layer? (in
> vector layer properties or in layer styling panel) If not, the layer
> will be only rendered as a texture (together with other layers) on the
> terrain.
> Cheers
> Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171220/4868e917/attachment.html>
