[Qgis-developer] Area calculation issues
Andreas Neumann
a.neumann at carto.net
Wed Feb 1 02:02:54 PST 2017
Sure - I'll send it to you as a geopackage file.
Andreas
On 01.02.2017 11:01, Nyall Dawson wrote:
> On 1 February 2017 at 19:55, Neumann, Andreas <a.neumann at carto.net> wrote:
>> Hi Nyall,
>> Thanks for the explanations. I should have read the explanations of the help text more closely. It explains it all.
>> However, there still seem to be issues. Consider the following results below. First column is the result of $area, second column is area($geometry).
>> Sometimes the results are very close, in other cases the difference is massive. Like in the very first row. 32'087 vs 190'605'589 square meters. This can't be explained with ellipsoidical vs. planimetric. In this first row, the result of area($geometry) (planimetric) seems correct, while the ellipsoidical result ($area) is massively wrong.
>> How can this huge difference be explained?
> Can you share your dataset?
> Nyall
