[Qgis-developer] Area calculation issues
Pedro VenĂ¢ncio
pedrongvenancio at gmail.com
Wed Feb 1 06:18:08 PST 2017
Hi Andreas and Nyall,
Please, share the conclusions here, after you find the problem.
Thanks!
Pedro
2017-02-01 10:02 GMT+00:00 Andreas Neumann <a.neumann at carto.net>:
> Sure - I'll send it to you as a geopackage file.
> Andreas
> On 01.02.2017 11:01, Nyall Dawson wrote:
>> On 1 February 2017 at 19:55, Neumann, Andreas <a.neumann at carto.net>
>> wrote:
>>> Hi Nyall,
>>> Thanks for the explanations. I should have read the explanations of the
>>> help text more closely. It explains it all.
>>> However, there still seem to be issues. Consider the following results
>>> below. First column is the result of $area, second column is
>>> area($geometry).
>>> Sometimes the results are very close, in other cases the difference is
>>> massive. Like in the very first row. 32'087 vs 190'605'589 square meters.
>>> This can't be explained with ellipsoidical vs. planimetric. In this first
>>> row, the result of area($geometry) (planimetric) seems correct, while the
>>> ellipsoidical result ($area) is massively wrong.
>>> How can this huge difference be explained?
>>> Can you share your dataset?
>> Nyall
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170201/ee800003/attachment.html>
