[Qgis-developer] Processing "Create script collection plugin" RuntimeError: Could not load layer: memory:
Victor Olaya volayaf at gmail.com
Thu Feb 2 04:06:01 PST 2017
Looks like, in that case, Processing is not correctly resolving the
layer source. A bit weird that it does it only under those
conditions...
I will take a look at it now, but please, open a ticket, in case it is
not an easy fix and needs more work
Thanks!
2017-02-02 12:56 GMT+01:00 Anita Graser <anitagraser at gmx.at>:
> Hi,
> I'm testing the "Create script collection plugin" functionality in QGIS
> 2.18.3.
> The plugin seems to be created fine and the scripts show up in the QGIS
> section of the toolbox. (Took me a while to find them there.)
> But when running any of the scripts, I get: RuntimeError: Could not load
> layer: memory:
> If I specify an output file instead of "Create temporary layer", the script
> runs fine and the output is created correctly.
> If I run the script stand-alone (without integrating it into a plugin),
> temporary output works fine.
> Is this a known issue? Or should I file a ticket?
> Best wishes,
> Anita
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
