[Qgis-developer] Outline/border -> stroke?
Neumann, Andreas
a.neumann at carto.net
Tue Feb 7 01:47:10 PST 2017
+1 for renaming to "stroke". "stroke" is also used as the term in SVG /
PDF specifications - the two most important vector graphic standards.
As a consequence, we would have related terms, such as "stroke-width",
"stroke-linecap", "stroke-dasharray", etc. See
https://www.w3.org/TR/2011/REC-SVG11-20110816/painting.html#StrokeProperties
Another candidate would be renaming everything "transparency" with
"opacity" - but I guess it would be more controversial ;-) And it would
mean that sliders would have to be reversed, as 100% opacity = 0%
transparency.
Andreas
On 2017-02-07 09:52, Nyall Dawson wrote:
> Hi all,
> Following up on one of the points raised by John Hawkison (author of
> the famous "my first weekend with QGIS" email), I'd like to raise
> discussion about renaming all use of outline/border throughout QGIS to
> "stroke".
> I've been thinking about this and I'm personally in favour.
> Why?
> - the terms border, outline and pen are used inconsistently throughout
> QGIS. Eg a polygon fill has an outline, a simple line has a pen.
> - the API is even worse... these terms are thrown around with no
> logical pattern. Even within single classes we mix and match
> - stroke is a good replacement for all these terms. It's also commonly
> used by most design software instead of border or outline.
> Any opinions here? Any objections if I made this change?
> Nyall
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170207/4535d695/attachment.html>
