[Qgis-developer] Symbolizing a discrete or a boolean raster
Alexandre Neto
senhor.neto at gmail.com
Wed Jan 11 10:31:14 PST 2017
Hello Stéphane,
IMHO, since it seems that you are not able/willing to sponsor the feature
yourself, sounds like a good opportunity for a small crowdfunding.
That way you would be able to contribute back to QGIS by giving your time
in finding a developer able to do it, setting up the crowdfunding,
advertise it, pay for part of it and so on.
It looks like a simple feature. it should not be very expensive (much less
than an ArcGIS license for sure), and if you think many people need this,
then the money will be easy to raise.
Alexandre Neto
Stéphane Henriod <stephanebek at gmail.com> escreveu no dia quarta, 11/01/2017
às 11:37:
One last message for today (sorry for spamming!)
It seems that this feature would actually be wished by "many" people (see
the ticket and the talks on user-). I just gave a try to 2.99-nightly and,
as far as I can see, nothing has been done in this direction (yet?).
I am wondering if there are massive challenges that I am overlooking or if
this could be implemented quite easily. In any case, do you think this is a
request that can be taken on to 3.0?
Thanks a lot to all the devs here... I feel quite bad for asking for a new
feature while not having the competences to contribute a tiny bit to its
development but I really feel this is one of the few major missing features
in QGIS right now (and will be happy to help on the feature requirements,
the tests, etc.).
All the best!
Stéphane
Le mercredi 11 janvier 2017, Stéphane Henriod <stephanebek at gmail.com> a
écrit :
Hi again
it seems that the requirements are related (although not 100% similar) to
this other open (and assigned) ticket: http://hub.qgis.org/issues/14449
I really hope to see this very needed feature in a coming version of QGIS
and happy to help wherever I can!
Cheers
Stéphane
Le mardi 10 janvier 2017, Stéphane Henriod <stephanebek at gmail.com> a écrit :
Hi
let me move here a request that has been shortly discussed on the
user-mailing list:
http://lists.osgeo.org/pipermail/qgis-user/2017-January/038793.html
http://lists.osgeo.org/pipermail/qgis-user/2017-January/038795.html
http://lists.osgeo.org/pipermail/qgis-user/2017-January/038801.html
and for which a ticket is open:
http://hub.qgis.org/issues/14845
I was said that some work has been done in this direction for 3.0 but I
don't know if it completely covers the feature request
When styling a discrete or boolean raster, there seems to be no direct
method, only a few workarounds. The feature I dream of would do the
following:
- A new render type "Discrete raster"
- One button allows to fetch all unique values form the raster (with a
warning message if there are more than XXX unique values)
- A color ramp is applied by default
- I can multi-select values and apply them the same style and / or the
same label
- I can remove values. The pixels with those values will simply not be
displayed
- I can save my color map and load an existing color map
So pretty much like the ArcGIS implementation:
http://resources.arcgis.com/en/help/main/10.1/index.html#/representing_unique_categories_such_as_land_use/009t00000074000000/
The current limitations I see (in 2.14):
- The discrete values must be entered manually, which is a pain for a
raster with many unique values (or if I don't know in advance what all
values are)
- If I click on *Classify*, QGIS will choose X values (based on the
number of classes and the classification method (continuous or equal
interval)), which no longer match the "exact" values of my raster. It
doesn't really make sense to classify a discrete rendering
- Although it is currently possible to style discrete rasters, the
procedure is not really intuitive for beginners
Is this a feature that is envisioned for 3.0? Is there anything I can do to
support it? (except coding it myself, since I don't have the skills for
that...)
Thanks a lot in advance
Cheers
Stéphane
“When you travel, remember that a foreign country is not designed to make
you comfortable. It is designed to make its own people comfortable." --
Clifton Fadiman
Clifton Fadiman
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170111/2647a20c/attachment.html>
