[Qgis-developer] Valid or invalid geom in PostGIS?
Andrea Peri
aperi2007 at gmail.com
Mon Jan 16 22:25:55 PST 2017
You have right.
The ST_MAkeVaild is capable to return a valid geometry. But it dont
remove redundant vertexs.
The redundant vertex is not always considered an Unvalidity (I guess
yes) so originally it was separated from the MakeValid function.
I guess is better if qgis do: before a removeredundants and after a makevalid.
Also pay attention to extract right type from the makevalid with the
couple forcecollection and after the extractcollection (or
collectionextract).
Regards,
A.
2017-01-16 13:12 GMT+01:00 A Huarte <ahuarte47 at yahoo.es>:
> Yes, Paolo is right.
> There is a project option to set the simplification default setting for new
> layers. But you can change this setting to each layer you want (e.g layers
> throwing these errors).
> Could ST_RemoveRepeatedPoints from QGIS 2.14 to be the guilty?
> http://qgis.org/en/site/forusers/visualchangelog214/#feature-use-st-removerepeatedpoints-for-server-side-simplification-with-postgis-2-2-or-newer-layers
> Best regards
> Alvaro
> ________________________________
> De: Paolo Cavallini <cavallini at faunalia.it>
> Para: qgis-developer at lists.osgeo.org
> Enviado: Lunes 16 de enero de 2017 13:00
> Asunto: Re: [Qgis-developer] Valid or invalid geom in PostGIS?
> Il 16/01/2017 12:59, aperi2007 ha scritto:
>> Hi,
>> I dont know any postgis specific server-side simplification option.
>> Perhaps you mean the "rendering --> Enable feature simplification by
>> default for newly added layers" ?
> yes, there is an option for server side simplification
> all the best
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Andrea Peri
qwerty àèìòù
