[Qgis-developer] What SAGA version is recommended?
Andreas Neumann
a.neumann at carto.net
Wed Jan 18 22:24:09 PST 2017
The error I get is:
io_gdal 0 -TRANSFORM 1 -INTERPOL 0 -GRIDS
"/tmp/processing7506c8fe191843708dbabb1ef3e015bc/2d0dfc6865944d63b13d24be8ecd081b/dom69602440.sgrd"
-FILES "/home/an/kurse/qgis/daten_uster/dom_6960_2440.tif"
Unknown option 'INTERPOL'
Apparently, INTERPOL was replaced by parameter RESAMPLING in newer SAGA
versions.
Anyone knows how I can get a working SAGA installation that plays nicely
with QGIS? or a Processing that plays nicely with newer SAGA versions?
Thanks,
Andreas
On 18.01.2017 20:59, Andreas Neumann wrote:
> Hi,
> I just installed SAGA version 2.3.1 and there are lots of io_gdal
> issues - basically with all raster operations (in combination with
> QGIS master 2 (2.18)).
> Seems like there are closed bugs on this very same issue (closed as
> being irrelevant) - f.e. https://hub.qgis.org/issues/13279 - opposing
> to what the ticket says, SAGA 2.3. doesn't work fine with QGIS.
> What version of SAGA is known to work fine with QGIS processing?
> Thanks for your help!
> Andreas
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170119/1427f107/attachment.html>
