[Qgis-developer] What SAGA version is recommended?
Werner Macho
werner.macho at gmail.com
Wed Jan 18 22:59:18 PST 2017
Hi!
There is already a ticket about it:
http://hub.qgis.org/issues/14735
We probably need to have a (public) repository (?) with downloadable
saga algorithm providers?
SAGA changes switches faster than they release versions ;)
regards
Werner
On Thu, Jan 19, 2017 at 7:24 AM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> The error I get is:
> io_gdal 0 -TRANSFORM 1 -INTERPOL 0 -GRIDS
> "/tmp/processing7506c8fe191843708dbabb1ef3e015bc/2d0dfc6865944d63b13d24be8ecd081b/dom69602440.sgrd"
> -FILES "/home/an/kurse/qgis/daten_uster/dom_6960_2440.tif"
> Unknown option 'INTERPOL'
> Apparently, INTERPOL was replaced by parameter RESAMPLING in newer SAGA
> versions.
> Anyone knows how I can get a working SAGA installation that plays nicely
> with QGIS? or a Processing that plays nicely with newer SAGA versions?
> Thanks,
> Andreas
> On 18.01.2017 20:59, Andreas Neumann wrote:
> Hi,
> I just installed SAGA version 2.3.1 and there are lots of io_gdal issues -
> basically with all raster operations (in combination with QGIS master 2
> (2.18)).
> Seems like there are closed bugs on this very same issue (closed as being
> irrelevant) - f.e. https://hub.qgis.org/issues/13279 - opposing to what the
> ticket says, SAGA 2.3. doesn't work fine with QGIS.
> What version of SAGA is known to work fine with QGIS processing?
> Thanks for your help!
> Andreas
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
