[Qgis-developer] Exported SLD size or displacementX/Y are not reimported correctly due to mm/pixel ambiguity
Jorge Gustavo Rocha
jgr at di.uminho.pt
Wed Jan 25 11:56:12 PST 2017
Maybe we can add support for uom (units of measure), like in [1], in the
export and import to/from SLD. I think we could archive better
compatibility if we use real world units. The uom attribute is
necessary. Numbers only have meaning when they also have units. I would
like to try this approach.
The qgis-geoserver-plugin uses a fixed SIZE_FACTOR = 4 to convert units
from QGIS (mm) to Geoserver (pixels).
Regards,
Jorge Gustavo
[1] http://geoserver.geo-solutions.it/edu/en/pretty_maps/style_uom.html
I think we should review all this import export
Às 16:38 de 25-01-2017, Andrea Aime escreveu:
> On Wed, Jan 25, 2017 at 4:21 PM, Luigi Pirelli <luipir at gmail.com
> <mailto:luipir at gmail.com>> wrote:
> BTW this suggest that any export fix would check also import side to
> maintain QGIS consistency.
> Yep... sorry I was not aware that the geoserver plugin was doing
> round-tripping of styles,
> never used it seriously and noticed the possibility to round trips
> styles only a couple
> of weeks ago
> Cheers
> Andrea
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Andrea Aime
> @geowolf
> Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 339 8844549
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio
> stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti,
> copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento
> contrario ai principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely
> for the attention and use of the named addressee(s) and may be
> confidential or proprietary in nature or covered by the provisions of
> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
> Protection Code).Any use not in accord with its purpose, any disclosure,
> reproduction, copying, distribution, or either dissemination, either
> whole or partial, is strictly forbidden except previous formal approval
> of the named addressee(s). If you are not the intended recipient, please
> contact immediately the sender by telephone, fax or e-mail and delete
> the information in this message that has been received in error. The
> sender does not give any warranty or accept liability as the content,
> accuracy or completeness of sent messages and accepts no responsibility
> for changes made after they were sent or for other risks which arise as
> a result of e-mail transmission, viruses, etc.
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
