[Qgis-developer] Exported SLD size or displacementX/Y are not reimported correctly due to mm/pixel ambiguity
Luigi Pirelli luipir at gmail.com
Wed Jan 25 14:04:00 PST 2017
The fact is that in the qgssymbollay[v2]utils.cpp there are already
all encode/decode UOM stuffs since 2012 (by G.Sucameli), but these
static routines seems not used in any part of qgis code. I'm still
investigating...
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 25 January 2017 at 20:56, Jorge Gustavo Rocha <jgr at di.uminho.pt> wrote:
> Hi,
> Maybe we can add support for uom (units of measure), like in [1], in the
> export and import to/from SLD. I think we could archive better
> compatibility if we use real world units. The uom attribute is
> necessary. Numbers only have meaning when they also have units. I would
> like to try this approach.
> The qgis-geoserver-plugin uses a fixed SIZE_FACTOR = 4 to convert units
> from QGIS (mm) to Geoserver (pixels).
> Regards,
> Jorge Gustavo
> [1] http://geoserver.geo-solutions.it/edu/en/pretty_maps/style_uom.html
> I think we should review all this import export
> Às 16:38 de 25-01-2017, Andrea Aime escreveu:
>> On Wed, Jan 25, 2017 at 4:21 PM, Luigi Pirelli <luipir at gmail.com
>> <mailto:luipir at gmail.com>> wrote:
>>     BTW this suggest that any export fix would check also import side to
>>     maintain QGIS consistency.
>> Yep... sorry I was not aware that the geoserver plugin was doing
>> round-tripping of styles,
>> never used it seriously and noticed the possibility to round trips
>> styles only a couple
>> of weeks ago
>> Cheers
>> Andrea
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Andrea Aime
>> @geowolf
>> Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 339 8844549
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio
>> stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti,
>> copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento
>> contrario ai principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be
>> confidential or proprietary in nature or covered by the provisions of
>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>> Protection Code).Any use not in accord with its purpose, any disclosure,
>> reproduction, copying, distribution, or either dissemination, either
>> whole or partial, is strictly forbidden except previous formal approval
>> of the named addressee(s). If you are not the intended recipient, please
>> contact immediately the sender by telephone, fax or e-mail and delete
>> the information in this message that has been received in error. The
>> sender does not give any warranty or accept liability as the content,
>> accuracy or completeness of sent messages and accepts no responsibility
>> for changes made after they were sent or for other risks which arise as
>> a result of e-mail transmission, viruses, etc.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Tel: +351 253604480
> Fax: +351 253604471
> Móvel: +351 910333888
> skype: nabocudnosor
