[Qgis-developer] QGIS Server - SSL handshake failed for cascading WMS
Neumann, Andreas a.neumann at carto.net
Fri Jan 27 07:31:19 PST 2017
I want to use a cascading WMS in QGIS server. I know it is not ideal,
perfomance wise, but it would be only for printing.
Problem is that the WMS uses https and QGIS server can't connect. The
QGIS server log shows a connect error:
Download of capabilities failed: SSL handshake failed
curl or wget on the same server works fine with the same ssl connection.
Anyone knows how I can overcome this SSL handshake issue? Do I need to
set up a separate certificat chain for QGIS server? I hope not ...
Thanks for any hints,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170127/42ed85c9/attachment-0001.html>
