[Qgis-developer] QGIS Server - SSL handshake failed for cascading WMS
Neumann, Andreas
a.neumann at carto.net
Fri Jan 27 07:48:39 PST 2017
Some more information on my server:
Linux CentOS7
qt 4.8.5
The server only allows tls connections, no SSLv2/3 or such vulnerable
stuff. Perhaps qt is too old to properly support tls ciphers?
Can I add an SSL "do not check exception" for specific connections of
QGIS server?
If yes - how would I configure that for QGIS server?
Thanks for any hints,
Andreas
On 2017-01-27 16:31, Neumann, Andreas wrote:
> Hi,
> I want to use a cascading WMS in QGIS server. I know it is not ideal, perfomance wise, but it would be only for printing.
> Problem is that the WMS uses https and QGIS server can't connect. The QGIS server log shows a connect error:
> Download of capabilities failed: SSL handshake failed
> curl or wget on the same server works fine with the same ssl connection.
> Anyone knows how I can overcome this SSL handshake issue? Do I need to set up a separate certificat chain for QGIS server? I hope not ...
> Andreas
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170127/595bf3a8/attachment.html>
