[Qgis-developer] Spatialite in QGIS master
Ramon Andinach
custard at westnet.com.au
Mon Jan 30 14:15:24 PST 2017
A quick question from user land.
Does having to explicitly set that option mean that spatialite might not be supported in the packaged releases of QGIS 3?
As someone that has (mostly) been paying attention to the continued stream of "shape files are so old and decrepit" comments that come up on these lists, and is making an attempt to learn one of the “modern” storage types (say spatialite) I’d like to know before 3 is released if I should be switching to a different path.
> On 30 Jan 2017, at 21:32, David Marteau <dmarteau at 3liz.com> wrote:
> PySpatialite is a totally obsoleted python package: you must explicitely load the mod_spatialite extension using the spatialite load_extension(..).
> Qgis use its own version of pyspatialite, but you must enable it in the build configuration as stated by Matthias.
>> Le 30 janv. 2017 à 13:10, Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk <mailto:saber.razmjooei at lutraconsulting.co.uk>> a écrit :
>> sudo pip3 install pyspatialite ?
>> Cheers
>> Saber
>> On 30 January 2017 at 10:48, matteo <matteo.ghetta at gmail.com <mailto:matteo.ghetta at gmail.com>> wrote:
>> Hi all,
>> I don't know if a miss some older discussion on this topic but I'm not
>> able to load SpatiaLite databases in QGIS 3.
>> It seems there there is no pyspatialite for python3:
>> Traceback (most recent call last):
>> File
>> "/home/matteo/lavori/QGIS/build-qgis3/output/python/qgis/utils.py", line
>> 598, in spatialite_connect
>> from pyspatialite import dbapi2
>> File
>> 647, in _import
>> mod = _builtin_import(name, globals, locals, fromlist, level)
>> ImportError: No module named 'pyspatialite'
>> I checked around on the web and I found an issue the github repo [0]
>> Has anyone a working SpatiaLite db on QGIS?
>> Thanks to all
>> Matteo
>> [0] https://github.com/lokkju/pyspatialite/issues/27 <https://github.com/lokkju/pyspatialite/issues/27>
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Saber Razmjooei
>> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk/>
>> +44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170131/5570518e/attachment.html>
