[Qgis-developer] Spatialite in QGIS master
Matthias Kuhn
matthias at opengis.ch
Tue Jan 31 00:41:29 PST 2017
Spatialite will be supported, core spatialite functionality does not
rely on python libraries.
If there are issues with db_manager spatialite functionality or other
python based modules, please contact your local package manager.
Technically we were reviewing a couple of alternatives to pyspatialite
(because it would be nice to have something properly supported for
python 3 by upstream) but we ended up not implementing these because
dynamic loading of extensions (and hence the spatialite extension) was
not enabled on every platform IIRC.
Matthias
On 01/30/2017 11:15 PM, Ramon Andinach wrote:
> Hi,
> A quick question from user land.
> Does having to explicitly set that option mean that spatialite might not
> be supported in the packaged releases of QGIS 3?
> As someone that has (mostly) been paying attention to the continued
> stream of "shape files are so old and decrepit" comments that come up on
> these lists, and is making an attempt to learn one of the “modern”
> storage types (say spatialite) I’d like to know before 3 is released if
> I should be switching to a different path.
>> On 30 Jan 2017, at 21:32, David Marteau <dmarteau at 3liz.com
>> <mailto:dmarteau at 3liz.com>> wrote:
>> PySpatialite is a totally obsoleted python package: you must
>> explicitely load the mod_spatialite extension using the spatialite
>> load_extension(..).
>> Qgis use its own version of pyspatialite, but you must enable it in
>> the build configuration as stated by Matthias.
>>> Le 30 janv. 2017 à 13:10, Saber Razmjooei
>>> <saber.razmjooei at lutraconsulting.co.uk
>>> <mailto:saber.razmjooei at lutraconsulting.co.uk>> a écrit :
>>> sudo pip3 install pyspatialite ?
>>> Cheers
>>> Saber
>>> On 30 January 2017 at 10:48, matteo <matteo.ghetta at gmail.com
>>> <mailto:matteo.ghetta at gmail.com>> wrote:
>>> Hi all,
>>> I don't know if a miss some older discussion on this topic but
>>> I'm not
>>> able to load SpatiaLite databases in QGIS 3.
>>> It seems there there is no pyspatialite for python3:
>>> Traceback (most recent call last):
>>> File
>>> "/home/matteo/lavori/QGIS/build-qgis3/output/python/qgis/utils.py",
>>> line
>>> 598, in spatialite_connect
>>> from pyspatialite import dbapi2
>>> File
>>> line
>>> 647, in _import
>>> mod = _builtin_import(name, globals, locals, fromlist, level)
>>> ImportError: No module named 'pyspatialite'
>>> I checked around on the web and I found an issue the github repo [0]
>>> Has anyone a working SpatiaLite db on QGIS?
>>> Thanks to all
>>> Matteo
>>> [0] https://github.com/lokkju/pyspatialite/issues/27
>>> <https://github.com/lokkju/pyspatialite/issues/27>
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> <mailto:Qgis-developer at lists.osgeo.org>
>>> List info:
>>> https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>> Unsubscribe:
>>> Saber Razmjooei
>>> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk/>
>>> +44 (0)7568 129733
>>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
