[Qgis-developer] how to avoid full-table scans to determine primary key, extents?
Chris Nicholas
cnicholas at housecanary.com
Tue Jan 31 15:24:11 PST 2017
revisiting this problem; it is really making QGIS totally unusable for the large tables we are manipulating.
UNECESSARY FULL TABLE SCANS == VERY BAD USER EXPERIENCE!!
If funds could be made available for this fix, is there anyone able/available to add this functionality, and avoid a full table scan on adding a layer, and on existing project start-up?
(i.e. add a new pop-up dialog when one adds a new vector layer to optionally/manually enter the layer extents)
this would make QGIS *-far-* more usable for “big data”
thanks!
Chris
> this is my observation on 2.14.8:
> if the postgis layer is added (via the "add postgis layer" dialog)
> with the "select at id" checkbox then when opening the attribute table
> this is iterated one time. If the table is large browsing it is not
> very snappy.
> If the layer is added without the "select at id" thing, then the table
> is always iterated twice before opening. If the "show features visible
> on map" option is selected, the table is still iterated twice (the
> entire table, not only the records of visible features) before
> opening. Browsing of large tables (once opened) is fast.
> One ticket I found that may be related
> http://hub.qgis.org/issues/10619
> cheers
> -- G --
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170131/76b6e214/attachment.sig>
