[QGIS-Developer] QGIS Server 2.x: issue with @map_scale variable vs. $scale
Nyall Dawson
nyall.dawson at gmail.com
Tue Jul 4 15:52:13 PDT 2017
On 4 July 2017 at 01:46, Neumann, Andreas <a.neumann at carto.net> wrote:
> Hi,
> In a QGIS project that should be published with QGIS Server, I used the
> @map_scale variable to define the font size with an expression, depending on
> the map scale. It works fine on QGIS Desktop, but on QGIS server GetMap
> requests it fails - the font-size (defined in map units) is constant and
> doesn't react to my scale dependent rule. The interesting thing, is, that
> the same rule works fine in GetPrint requests.
> If I change my rule to use $scale instead of @map_scale, my label rule works
> fine.
> Could it be that the @map_scale variable doesn't work in QGIS server GetMap
> requests?
Exactly - it's a consequence of QGIS 2.x server using the really old
map renderer, which means it doesn't have access to any variables
relating to the current map scale/extent/etc. This is also why 2.5d
renderer is quite broken on server under 2.x.
The good news is that it's all fixed with 3.0.
Nyall
> Here is my expression:
> CASE
> WHEN @map_scale <= 251 THEN 1
> WHEN @map_scale > 251 AND @map_scale <= 501 THEN 2
> WHEN @map_scale > 501 AND @map_scale <= 1001 THEN 3
> WHEN @map_scale > 1001 AND @map_scale <= 2001 THEN 4
> WHEN @map_scale > 2001 AND @map_scale <= 3001 THEN 6
> WHEN @map_scale > 3001 AND @map_scale <= 4001 THEN 7
> WHEN @map_scale > 4001 THEN 8
> END
> Thanks for your ideas.
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
